On my way home I checked it and it works. I saw a litte bit of water on my ford logo and some drops running from the camera washer ![]()
Frontkamera nachrüsten
Have you had someone looking at it while trying?Maybe the hose to the water tank is empty as washer not in use very often and water condensed.
Does it at least come out? If not, you should go to your dealer.
Regards
CosmonovaThanks for the hints. I tried all of that. It does not come out by itself, but it does if I try to pull it manually.
I went to my dealer, they didn't even know it is a washer in there. We updated the software, including the Body Control Module (BCM), hopping that it is a software related problem. No luck.I will pay them another visit to remove the bumper and to check the water tank, the pump(s) and the hose. I am not sure if there is a separate pump for this washer or if it is using the same one as for the windshield but I guess we will find out.
To be honest, I suspect an assembly issue, since it has never worked.
Cheers,
Bogdan -
Maybe the cable of the pump is not plugged in correctly. Had this in another car. Handsfree mic did not work. Cable was plugged but not till the end when it clicks in.
Good luck -
echt? ist mir auch nicht aufgefallen - ist das inklusvie oder braucht man hierfür die scheinwerfer waschanlage?
wie kann ich meine frontkamera waschen lassen? in dem ich die frontscheibe wasche? -
Gute Frage, habe beides und daher auch die Düse vorne.
Lieber wäre mir die allerdings hinten, so schnell wie die Kamera verdreckt. Oder eine, die hinter einer Klappe verschwindet. -
Da haste wohl recht.
ja, hinten wäre es deutlich wichtiger, dass man die Kamera automatisch reinigen könnte! Eine kurze Regenfahrt und alles ist verdreckt!
